6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
no throttle sometimes?
Old Sep 16, 2010 | 10:30 PM
randy9726's Avatar
Default no throttle sometimes?
this is my second 6.0 should of learned my lesson first time! right? every once in a while I go to take off and when i press on the throttle the idle doesnt pickup, then it will start to rev after a few seconds and it usually blows alot of smoke. it only happens maybe once a week truck has 85000 miles and is all stock any ideas? please help my local dealer likes to just experiment with changing parts and slapping u with a huge bill. thanks
Old Sep 17, 2010 | 10:47 AM
gixxertricks's Avatar
any help for Randy? (and possibly me)
Old Sep 18, 2010 | 08:29 AM
Diesel Powered Rocket's Avatar
This hesitation could be several things.
Your EBP sensor may be bad or erratic. Should see codes P2263 or P0299 if the exhaust backpressure sensor is faulty. This should also exhibit buck/jerk, hesitation, lack of power, stalling, stumble, black smoke, surging, rolling idle, changes in engine sound at idle or when driving at a steady speed. This sensors signal reading should be .88 - .9 volts at sea level and decrease by .1 volt for every 2000 feet above sea level. Check with the key ON but engine OFF.
This may be low boost caused by the turbo not spooling up as you move the throttle.
The variable vanes may be coked up and sticking from time to time. Remove turbo and clean it up yourself.
Can you hear the turbo whistle as you step on the throttle when its acting up?
Check all of your intercooler hoses before the turbo for leaks.
Old Sep 18, 2010 | 08:05 PM
randy9726's Avatar
Default update
i cleaned my egr valve yesterday it was pretty sooted up but dry. put it back in and the truck ran worse valve was stuck partially open and after i cleaned it moved back to closed position still have no engine light on. I unplugged egr while it was running and the problem cleared up so looks like I will be going with an egr delete asap. thanks for all the help
Old Oct 28, 2010 | 01:52 AM
pushingmy6.0's Avatar
did you ever get that egr delete in?? my truck is doing the samthing..
Old Oct 28, 2010 | 08:32 AM
Mdub707's Avatar
Do an EGR delete, and while you have the turbo off, clean it up. Sounds more like a turbo issue to me. I'd say the combination of cleaning the turbo and doing the delete will help tremendously.
12vWoodHauler
Sep 30, 2015 07:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
Jake202
Jun 21, 2015 09:42 PM
Jmohr52
Mar 4, 2015 01:18 AM
1stgenswap
Nov 3, 2014 09:45 PM
