95 7.3
Old Sep 10, 2010 | 08:52 AM
harry22's Avatar
Default 95 7.3
My buddy bought the truck yesterday, clean az truck. The guy he bought it from told him it has a bad injector which you could tell but as the truck came to temp in smoothed out. On the way home the truck ran fine but all of a sudden it surged and died. it wasnt hot and had good oil pressure BUT when we pulled the dip stick there was nothing on it, oil was leaking out of the valve cover that the ford teck used rtv to seal it back up with after he tested the bad injector. I figured if it was that low it didnt have enough oil for the HPOP system. Filled with oil and still no start. Checked fuel filter and it was full of fuel. Where do we go next please help.
Old Sep 10, 2010 | 12:14 PM
Noobie's Avatar
when turning over does the tach spin? if not try n replace the cam position sensor. jus one place to start. Those valve covers are bad are bad about warping when over torqued, when u get them off use a straight edge and check that. GL
Old Sep 10, 2010 | 02:48 PM
harry22's Avatar
it sat on the side of the road last night we will get it and for sure check that out. Any ideas on how to get this thing to fire so we can get it on a trailer?
Old Sep 10, 2010 | 07:48 PM
marteld's Avatar
if it is really low on oil it is possible to have air in the hpop system and that will cause it not to start had that happen on mine when the o ring let go on the hpop rail behind the alternator had to fill it with oil and turn it over till it fired hope fully that is what is wrong with it
Old Sep 12, 2010 | 11:42 PM
harry22's Avatar
this can be closed
Old Sep 14, 2010 | 04:32 PM
the_new_kid's Avatar
What did you find to fix the problem?
Old Sep 14, 2010 | 04:47 PM
harry22's Avatar
Started hauling beets so I haven't been able to work on it. The kid that owns it is farming now too so we wont get to it till after harvest.
Browe347
Dec 11, 2016 02:59 PM
Toms73
Mar 23, 2015 08:31 PM
tumble72
8
Nov 27, 2014 10:31 PM
Altonlee
9
Oct 8, 2014 02:31 PM
Browe347
Sep 30, 2014 11:35 PM
