Airdog help !!!
Old Sep 7, 2010 | 10:12 AM
dove33's Avatar
Default Airdog help !!!
I just installed an airdog 150 with a 40 psi spring on my 96 12V. Everything went smooth with the install. My problem is that I think the airdog is pushing fuel through my overflow valve. The overflow valve is adjustable so I have it as tight as it will go. When I pull the inj. pump return line off of the tank and energize the airdog I get a high flow of fuel from the return line. You can also hear the fuel flowing through the overflow valve in the engine bay. Will this be fixed if I get a higher rated spring for the overflow valve or should I get the 30 psi spring for the airdog ? Also if I run the truck until this is fixed am I going to run the risk of screwing something up ? Truck sounds and runs great except for the overflow valve issue. Airdog is a little noisy but I think that is related to the overflow issue.
Thanks in advance for any and all help.
Old Sep 7, 2010 | 10:31 AM
Red_Rattler's Avatar
High Tech Redneck
Had the same prolem with mine! fixed it and got some more power with a aftermarket OFV from http://torkteknology.com/products.ph...W-VALVE-OFV040
Old Sep 7, 2010 | 11:34 AM
kegs99's Avatar
where does this spring go? there was a spring in my bag but i never used it..didn't even see it in the instructions. did i mess up?
acj
9
Dec 26, 2015 09:54 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
dirtymaxrens
Price Quote - Request A Price
Jan 24, 2015 08:02 PM
justinsbeck
Nov 21, 2014 11:53 AM
