#4 puking oil
Old Aug 29, 2010 | 02:22 PM
Beelzeboss's Avatar
Default #4 puking oil
it was running fine, then i put the new injectors in and ran it down the strand, it was night so i couldnt really see much and it seemed fine so i parked it and went to sleep. woke up the next day, started it up and there was smoke comin out the stack, whitish gray, i thought it might just be some haze from all the fuel, so i took it around base a little bit and it was pretty much impossible to drive without pouring smoke, whitish gray still, i stomped it and it turned black, but still a lot of smoke when i was drivin easy, so i parked it.i come back later and notice a little oil under it, so i pop the hood and look, and it looks like its comin from the top turbo, start it up and sure enough a very light mist is comin out between the hotpipe and the exhaust housing, so i pull the turbo off and it seems fine, then i notice oil in the back half of the manifold, so i pull the manifold off and see that the oil was comin from #4.
so im thinkin stuck valve, or bad rings
Old Aug 29, 2010 | 09:25 PM
dan33klein's Avatar
could be a valve seal bad, but im not sure if it could leak that much oil. someone with more knowledge will chime in
Old Aug 30, 2010 | 03:07 PM
cumminspwr11's Avatar
i could also be a bad valve stem seal, i have seen those go bad on a cr, can you smell the oil burning in your exhaust?
Old Aug 30, 2010 | 06:23 PM
Beelzeboss's Avatar
not that i noticed, im not sure that it was burning it, seeing as how it was coming out of the turbo while it was running
avatardvr
18
Aug 8, 2019 12:38 AM
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
coors_man_2005
Dec 15, 2014 10:23 AM
