first gen power steering.
Old Aug 22, 2010 | 07:16 AM
Budgreen's Avatar
Default first gen power steering.
ok, first gen dodge 12v
took a trip the other day and drive about 4hrs highway, pulled into a toll booth and had no power steering, took a look and it was pretty low, so I topped it off and went on my way, still didnt work worth a crap.
I replaced the pump and lines a month or so ago, had no leaks other than a drip from the gearbox here and there so its a mystery as to wwhere the fluid went. what I filled it with is still in there 400 miles later but i cant tell if its circulating.
at idle I cant turn the wheels at all, at high rpm's i can turn them a little but with some omph to move the wheel. plenty of travel feels normal to drive on highway, but normal roads i have to wind out 1st or 2nd gear to get enough turn to swing a corner wide.
new pump dead?
gearbox died?
any way to test them?
Old Aug 22, 2010 | 08:18 AM
NadirPoint's Avatar
It probably leaks more going the road due to deflection caused by worn gear under load at pressure stressing or opening a seal. That's why you didn't see where it went.
Bad gear, would be my guess.
Old Aug 22, 2010 | 09:02 AM
Budgreen's Avatar
i'm about to disconnect it from the axle and see how well if at all it moves in a bit here. hoping thats not the problem because i'm sure nobody stocks a gearbox, much less anything else for this truck.
Old Aug 22, 2010 | 09:56 AM
NadirPoint's Avatar
They are common parts. Around $100 or so at NAPA IIRC...
Old Aug 22, 2010 | 10:38 AM
Budgreen's Avatar
Common parts..
the only "common" part I found in stock so far is a u-joint.. and between 4 different parts stores I had enough to do the front and rears .
it's $161 after core, special order.
Old Aug 22, 2010 | 12:40 PM
NadirPoint's Avatar
Price went up, whodathunkit! I remember getting a reman at NAPA about 4 years ago for around $100 - yes w/core, and they had to order it in overnight, like almost everything else for a vehicle more than 5 years old...
Old Aug 27, 2010 | 10:32 AM
Budgreen's Avatar
gonna replace the pump this weekend under warranty, otherwise im rebuilding the box. I have no way to troubleshoot other than replacing stuff.
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
