Mercedes 300d 5cyl turbo swap
Old Aug 16, 2010 | 01:34 PM
jeep-dsl's Avatar
Default Mercedes 300d 5cyl turbo swap
Was very inspired by mercedes to wrangler swaps on website. Just purchased 84 300d to swap into a wrangler. Engine and trans now out of car. Any helpfull hints would be greatly appreciated. thanks jeep-dsl.
Old Aug 22, 2010 | 10:05 PM
jeep-dsl's Avatar
This weekend we bought the 95 YJ Wrangler with blown 6 cylinder to do the mercedes 617 turbo diesel swap. Engine is now out and working on the 1st adapter for flywheel.
Old Aug 22, 2010 | 10:48 PM
Rustin's Avatar
I have no info for you. I thought it would be wrong of me not to post. Just make good measurments, which I am sure you already have. Excellent Idea never heard of anyone doing that. Just so you know those power-plants have very good Mpg on the highway. some have been able to do well over 75 and still get close to 30 mpg. when you start the mods for more power and efficentcy I would starrt with the Pistons. look at the way the fuel has eched a path on them. The preinjection chamber I would leave alone. The piston is the area to look at for now. The Pumps are euro boch and are capeable of 3200psi in stock form.
Old Aug 24, 2010 | 07:29 AM
ForcedInduction's Avatar
Very rarely. Mid-20's is more accurate.
Thats the very last place to even consider touching.
That is not an etch, its part of the casting.
Old Aug 24, 2010 | 10:33 AM
Horns's Avatar
I don't have any experince with any of the mercede's diesels but I hear that one is a pretty good engine. If you really want a lot of info start searching around www.4btswaps.com They have a complete section on the mecerdes engines.
Old Aug 24, 2010 | 12:19 PM
FTE's Avatar
FTE
Just be careful with the ballance of the flywheel when swapping. The factory ballanced each motor individually as a complete assembly, making the finall adjustments for ballance on the flywheel. So each flywheel has different ballance. Make sure you mark the position of the flywheel to crank (the hole spacing is even) so you can match the ballance of your new flywheel. You should be happy with the performance of the stock motor in the jeep so long as you have the valves adj. properly, free flow exhaust,egr delete, cold air intake, good injectors and the correct gearing (around 411 depending on the tire size) good luck!
Old Aug 24, 2010 | 12:39 PM
Rustin's Avatar
Originally Posted by ForcedInduction
Very rarely. Mid-20's is more accurate. (I did say Some. Rustin)
Thats the very last place to even consider touching. (your probably right. I have seen to much and have gone info happy the wrong direction. Rustin)
That is not an etch, its part of the casting. (Hold on now. I am talking about how the fuel creats an etching (well more like cleans a path) over the casting, kinda like a star pattern that a cummins or Dmax makes when you over fuel or advance fuel timing. My appologies for not being more clear and less vague. I was trying to get him to ask questions. then let the info fly. Rustin)
Do what you need to do man. nothing to hold you back with your jeep. alot of info. Have fun.
Old Aug 24, 2010 | 07:11 PM
Originally Posted by Horns
If you really want a lot of info start searching around 4btchops.com They have a complete section on the mecerdes engines.
A very poor section with no experienced members.
This is a far better resource: superturbodiesel.com - tuning performance turbo diesel mercedes, W123, W116 and up. OM617, OM60X
Rarely. Most flywheels are neutrally balanced. Still, care should be taken to make sure its not one of the 1/10 that isn't.
cold air intake
One is already installed as stock equipment.
Old Aug 24, 2010 | 08:28 PM
Benzer1's Avatar
Default Mercedes Jeep
Check out the threads by Vlado, FTE, and myself. The 5 cyl Benz swap is not that bad. The engine is the perfect size for a Wagoneer/Cherokee IMHO...............
John
straight six mafia
Mercedes
Aug 21, 2015 10:19 AM
swelbe
Apr 7, 2015 01:08 AM
n2brk
Feb 21, 2015 09:05 AM
diesel fit her
Nov 13, 2014 02:43 PM
GreenDieselF
Oct 20, 2014 02:05 PM
