airdog question
Old Aug 16, 2010 | 12:12 PM
oglejust's Avatar
Default airdog question
I have my airdog hooked in with my radio fuse and it runs every time my key is on. I thought they just primed then shut off. Do I have it hooked up right or no.
Old Aug 16, 2010 | 12:16 PM
Red_Rattler's Avatar
High Tech Redneck
All its doing it energizing a relay, so as long as you dont have some hardcore aftermarket head unit youll be fine
Old Aug 16, 2010 | 12:59 PM
oglejust's Avatar
Right but is the pump supposed to run all the time
Old Aug 16, 2010 | 01:02 PM
94 12valve's Avatar
yes should hold a constant press
Old Aug 16, 2010 | 01:04 PM
High Tech Redneck
yep the only thing is if you turn the key to the acc to just have the radio on while u sit there the pump will run as well. If thats a problem, you can use a test light to prob the fuse box to find a keyed on only source to put the fuse into
Old Aug 16, 2010 | 01:55 PM
12vcummins96's Avatar
i have mine on a keyed on only spot
Old Aug 16, 2010 | 02:25 PM
94 12valve's Avatar
thats the way to go right there
Jul 21, 2015 09:30 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
