Brake Controler
Old Aug 11, 2010 | 09:59 PM
BlackCloud96's Avatar
Default Brake Controler
Does anyone know if my dodge from the factory has a plug in for a brake controler or do i have to hard wire it in. If it does where is it located and pictures of what im looking for would be great thank guys!!!!!!
Old Aug 11, 2010 | 10:02 PM
dan33klein's Avatar
i have a 96 also, i think there is one from the factory, if not, you just need switches 12v, ground, wire from your brake lights,(brakepedal), and the wire running to your rear plug for trailer
Old Aug 12, 2010 | 03:32 PM
do you have one installed on your truck also if so can you tell me where to look
bump
Last edited by BlackCloud96; Aug 12, 2010 at 03:32 PM. Reason: Automerged Doublepost
Old Aug 12, 2010 | 03:34 PM
wes-cummins's Avatar
THE PLUG IS UP UNDER THE DASH SOMEWHERE ABOVE THE PEDALS,
I THINK IT WAS TAPED TH THE BACK SIDE OF A BRACKET OR SOMTHING
IF YOU HAVE A 7 PIN PLUGIN IN THE BACK THERE SHOULD BE A PLACE TO PLUG A CONTROLLER TO
Old Aug 12, 2010 | 04:34 PM
ok
Old Aug 12, 2010 | 10:20 PM
AfflictedPast's Avatar
Yes sir, if you have a factory tow package you should have one.
On my 96 it was up high near the firewall in the far left corner. my brake controller came with the harness i needed to plug and play, made it a 5 min install. good luck
Hogridenfool
Nov 20, 2017 04:37 PM
Turbo67
Jul 25, 2015 02:26 PM
corksil
Jun 30, 2015 06:58 AM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
