85 K5 Diesel SWAP 6.5
Old Aug 7, 2010 | 01:02 AM
fishing4820's Avatar
Default 85 K5 Diesel SWAP 6.5
Im putting a 6.5 into my 85 k5 with a current 305 in it. I am wanting to know what all I will need exactly to pull this off. I have an automatic stock trans in it. Not sure what it is exactly. An what are some ways i could get as much power as possible out of the 6.5
Old Aug 7, 2010 | 09:10 AM
fumminsplease's Avatar
Different torque converter, fuel system or modify it, motor mounts from a diesel burban or pickup, shorten or lengthen drive shafts, not sure if the 6.5 was intercooled but if it was you would need one of those, different radiator im sure that 305 one is pretty small,and figure out the glow plugs. Probably missing a few things. Also from what Ive heard you cant get very much power out of a 6.5, you can actually get about the same from a 4bt. good luck
Old Aug 7, 2010 | 09:59 AM
2MuchJunk's Avatar
You need the torque converter, radiator, oil cooler lines, and a relay to run the glow plugs. Motor mounts, fuel system up to the engine, and drive shafts are all the same. Its pretty simple swap you pull the gasser out and put the diesel in. Take the hot wire to the distributer and plug it to the shutoff solenoid on the injection pump. Turn the injection pump up, turn the turbo up or replace it with a better one, and put better injectors in it. You can easily get over 300 hp with it. Heath diesel has one making over 500hp.
Old Aug 8, 2010 | 07:49 PM
FastCR's Avatar
sounds like a cool swap, should be really straightforward.
Old Aug 9, 2010 | 02:38 PM
Yeah Scratch that. Im going with a 6bt cummins. I know it will be more work but also.. MORE POWER!!
Old Aug 9, 2010 | 03:32 PM
ForcedInduction's Avatar
As well as a dime a dozen.
Old Aug 10, 2010 | 01:24 AM
FastCR's Avatar
x500
Old Aug 22, 2010 | 08:58 AM
butcherman's Avatar
If you go with the cummins, you might as well ditch your stock tranny, it wont live. If you don't have them already, an axle swap as well.....money, money, money
Brclouse
Nov 18, 2015 08:44 AM
JohnFromVt
Aug 3, 2015 06:15 PM
Easton18t
Jul 30, 2015 02:06 PM
JamesL91
Mar 15, 2015 06:11 PM
Snoobly
Dec 11, 2014 11:59 AM
