92 Cummins DIED, Shut Down. HELP!
Old Aug 2, 2010 | 07:15 PM
MegaMan's Avatar
Default 92 Cummins DIED, Shut Down. HELP!
I was running down the road about 50mph, everything's fine, and started to slow down. I hit the throttle but no response so thought my linkage came off again. But then I realized engine had shut down and had NO power. I coasted off into an empty lot and tried to start but absolutely NO power from the ignition switch. Checked all battery cables, alt. cables, everything's fine. Battery's hot, headlights & flashers work, not sure what else is not working. Turn signals not working. Absolutely NO power on dash except dash lights. No radio, no gauges, nothing from ignition switch. Can't see anything burned, broken, disconnected, didn't smell anything odd - nothing. Its just like I turned the key off and shut her down and won't restart. Have no idea except maybe ECM? Need some advice quick - I'm stranded! Thanks!
Old Aug 2, 2010 | 08:37 PM
brindle_bull's Avatar
sounds like a fuse or a ground issue
Old Aug 2, 2010 | 09:47 PM
MegaMan's Avatar
Got her fixed, was the orange fusible link.
camp9
Mar 25, 2017 07:40 AM
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
