92 6.5 lost 5th gear (nv4500)
Old Aug 1, 2010 | 07:37 PM
garp1108's Avatar
Default 92 6.5 lost 5th gear (nv4500)
i was cruising down hwy shifted into 5th gear let out the clutch and it was like it was in neutral. took out and pushed back into gear and held it. it did not want to grab and i could feel it popping out of gear but not grinding. pulled into gas station and shifted thru all the gears letting out the clutch in each one. seemed to be ok went to head back home and could not get into any gear at all. finially got it into 3rd gear and left it. gotta love the diesel red lights and everything in 3rd. got home and all gears seem to be working again. but not driving untill its fixed.
i am guessing but do you think its just the shifting forks wore out / broke? 198k on truck and also days before the speedometer started bouncing. related?
Old Aug 2, 2010 | 03:35 PM
Budgreen's Avatar
NV4500?
I bet the nut that holds 5th gear on loosened up and or fell off. it's a fairly common problem. check the second gen cummins section and there should be plenty of info on it. good luck!
Old Aug 3, 2010 | 03:57 PM
garp1108's Avatar
thanks,
i am hoping to get it out this week. i will let you know what i find
Old Aug 3, 2010 | 05:01 PM
toy4xchris's Avatar
Originally Posted by Budgreen
NV4500?
you beat me to it I was gonna recommend the same thing.
99&91cummins
Feb 28, 2015 09:28 AM
miked2805
Oct 29, 2014 06:20 PM
offroad00
Oct 21, 2014 01:48 PM
