Odd start/idle
Old Aug 1, 2010 | 07:13 PM
mike10114's Avatar
Default Odd start/idle
I just had to replace the Fuel injection pump on my 1992 6.5
Now whenever it starts cold it will smoke a bit like it is running rich.
But that will pass and it will run fine, till you go down the highway and it will cut out a bit and just run off.
Also whenever you shut it off warm, and come back to it and start it while still warm, it will idle/drive for a little bit, then die. Try to start it again and it cranks over for a long time and will fire up and wont die till next time.
I believe that they turned the pump up, and advanced the timing a bit, could it be turned up to much or outta time. Or do you think that the injectors just aren't working right?
-Mikel
Old Aug 3, 2010 | 12:48 PM
Woody35's Avatar
did they hook up the cold idle switch
51Hudson
10
Aug 5, 2015 12:32 AM
moparman70
Jul 30, 2015 12:38 AM
Cutlass26
Mar 22, 2015 05:46 PM
6btf350cummins
Dec 16, 2014 07:23 AM
