knocking noise??
Old Jul 30, 2010 | 01:06 AM
lil bit's Avatar
Default knocking noise??
new here, so hope I'm in the right place,no short was to ask, need ANY suggestions, loaned my truck (1st & last time) was needed to move a travel trailer, one way trip about 150 miles,put in a new clutch the week before, rollin like a champ, made the trip going ok, friend was being nice and charged the AC while he had my truck, one thing may have nothing to do with the other, but--he was starting back, got about 10-15 miles into trip, things going good, then he calls "your trucks knockin" I'm like duh- it's a diesel, he says "NO, I mean really knocking, loud", I'm like get it as close to home as you can, so the tow doesn't cost me more than the truck did, with trailer still hooked, they brought her home,(I was at work) got home that night, cranked her up, LOUD knock, can't tell from where, all fluids at proper levels, no smoke, has all the power she had to begin with, if you listen REAL close, slight miss, starts everytime, the check engine light is not on,aside from the noise, shes as good as she's ever been, any suggestions will be GREATLY appreciated. Sorry so long
Old Jul 30, 2010 | 01:23 AM
BIG NIG's Avatar
it will help if you let everyone know what your driving
Old Jul 30, 2010 | 02:07 AM
lil bit's Avatar
my bad, 1999 Ram 2500, 5.9l Cummins, 5 speed--Thank You!!
my bad, 1999 Ram 2500, 5.9l Cummins, 24 valve, 5 speed. Thank you!!
Old Jul 30, 2010 | 07:51 AM
Sideshow's Avatar
Well for starters if you just put a clutch in it the flywheel bolts may not have been tightened to spec and could have worked loose, however if flywheel was not removed it could be in the clutch. I would suggest get under the truck and listen by the bellhousing to see if that is the source of the knock
Old Aug 1, 2010 | 08:29 PM
CumminsPower127's Avatar
Well it might be the new clutch. Is it a double disc? double discs knock noticebly and loud on some trucks
chootem
Jul 18, 2015 08:29 PM
Boatman
Mar 20, 2015 10:00 AM
Dak_summers
Jan 22, 2015 08:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
