Turbo compressor housing leak
Old Jul 26, 2010 | 01:31 AM
bryson's Avatar
Question Turbo compressor housing leak
Just put an HE351 on my '01 Cummins, and it required clocking the compressor housing. Problem is that where the compressor housing meets the center housing (retained by a ridiculously large, hard to remove snap-ring) it leaks boost pressure. I sure didn't notice any sort of sealer between the two pieces when I disassembled it, but I'm wondering if I could take it apart again and use a thin smear of silly-cone?
Any ideas?
Thanks for helping!
Old Jul 26, 2010 | 01:56 AM
Benjamin's Avatar
Bombardier
if i recall correctly you can buy a gasket for that. i'm not going to say that the silicon will or will not work but with the tolerances on these new turbos i would disassemble the compressor housing and make sure the mating surfaces are clean and aligned properly. also make sure that the big snap ring is seated properly in the groove.
Old Jul 26, 2010 | 02:34 AM
bryson's Avatar
Everything was pretty clean and the snap ring is certainly seated all the way. I know there was no gasket when I pulled it apart, and I'm not sure if the snap ring would seat if there was a gasket in there (I don't think the extra thickness of the gasket wouldn't leave room for the ring.)
It leaks where the gap in the snap ring is, but I'm assuming the leak would just follow the gap if I turned the ring...
makuloco2000
Dec 20, 2015 11:19 PM
honda89
Oct 17, 2015 01:08 PM
n2brk
Feb 21, 2015 09:05 AM
ash23k
Dec 30, 2014 08:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
