hx35 wastegate
Old Jul 14, 2010 | 06:24 AM
timdale's Avatar
Default hx35 wastegate
Has anyone had any issues wiring the wastegate shut on a hx35? I have a 93 that I put a hx35 exhaust housing and the wastegate won't fit. I put in a boost gauge and EGT, and have only done one turn of the power screw. I don't really pull anything heavy, should I have any isssues? Thought maybe I would make a cable operated wastgate control incase the boost got to high
Old Jul 15, 2010 | 01:01 PM
85_305's Avatar
Being Evaluated
Post this in the 12v Cummins section dude.. you'll get way more answers there. Wiring shut the WG is a bad idea in my opinion.
Old Aug 2, 2010 | 01:23 AM
ForcedInduction's Avatar
The wastegate is there to prevent the turbo from overspeeding. If you don't want a wastegate you need a turbo with a larger A/R housing so the engine won't blow it up.
Old Aug 2, 2010 | 04:57 AM
BlackCloud96's Avatar
im running a hx35 with a plugged wastegate im at 40 psi of boost it is fine for now if anything i might waste the charger but i want a bigger one anyway
Old Aug 2, 2010 | 05:12 AM
At 40psi the turbo is extremely inefficient and overspeeding. Good luck saving your engine when the compressor grenades.
Old Aug 2, 2010 | 05:18 AM
i have already popped a couple turbos both of mine shot the exhaust wheel out the stack and if it does it does you pay to play bud thanks for the good luck also
question what do u run?
Last edited by BlackCloud96; Aug 2, 2010 at 05:18 AM. Reason: Automerged Doublepost
Old Aug 9, 2010 | 05:03 AM
timdale's Avatar
Well, I'm running a stock 93 12v with 1 1/2 turns on the power screw and I have the stock H1C comp. housing and have yet to hit 20 psi, but I havn't been over 2200rpm's or pulled anything. I can't imagine that I'm gonna go much over 25psi on a stock 12v anyway, just not enough fuel
cummaprt704
May 9, 2015 04:09 PM
xmedina
Wanted To Buy (WTB) - Used
Mar 2, 2015 08:51 PM
wpg6.5
Feb 19, 2015 07:27 PM
D-350 dually
9
Feb 11, 2015 12:37 AM
BIG SOCHA
Oct 23, 2014 11:01 PM
