Calibrating the fuel pump????
Old Jul 8, 2010 | 09:20 PM
jdcoop8791's Avatar
Default Calibrating the fuel pump????
I was looking on ebay and i found a performance resistor for my 1994 6.5. It says that the resistor range from 1 to 9, This calibrates the amount of fuel that the injectors send. It says that the resister plugs inbetween the harness and the PMD.
Is this a good upgrade, or is this just another scan? I want more fuel and more power but i don't want to have to spend $300 on a chip. Can you help me with this or does anyone know any info about this at all?
Old Jul 8, 2010 | 10:57 PM
Woody35's Avatar
its true it does plug in between the harness and pmd. stock is #5 and you need it or it will throw codes. it is also true that it increases fuel but nothing you will feel. its a very very very small amout of fuel that is injected. sorry but the only cheap way to get more power is a chip.
you can wire a boost fooler into the truck but it wont add much power since your not adding any fuel just boost
Old Jul 9, 2010 | 08:48 AM
jdcoop8791's Avatar
Ok thanx a lot
Old Jul 9, 2010 | 11:03 PM
2MuchJunk's Avatar
Changing from a #5 to a #9 is a waste of time unless you have the pmd out and a #9 in your hands. I went from a 5to a 9 just because the pmd I had had one in it and I couldn't tell the difference.
Old Jul 10, 2010 | 10:42 PM
jdcoop8791's Avatar
Ok thats what I was wonderin. so what is the cheapest chip i can get then?
Old Jul 10, 2010 | 11:27 PM
Woody35's Avatar
google engh motors or walking j designs they have the cheapest chips i think
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
