Possible Blown Head Gasket Coolant out of Exhaust Modified 04 6.0
Old Jul 3, 2010 | 07:46 PM
2everest's Avatar
Default Possible Blown Head Gasket Coolant out of Exhaust Modified 04 6.0
Hey guys,
We took a trip up to VaBeach to see family this nice fourth of July weekend and our 04 6.0 has been pouring coolant out of the exhaust at startup (maybe a half a quart each startup) She has been losing coolant for weeks, and I assumed a leak, but could never find a definite possibility. Just today she started spitted it out of the tailpipe. It is almost straight coolant coming out, a little dirty from exhaust, but not oily, or mixed. Then she will smoke white for a few minutes I guess until it burns off. Occasionally while putting her around, trying to diagnose, I will see white smoke at idle.
This is a heavily modified truck, suspension, and performance wise, and I am pretty sure a blown head gasket is the cause. I wanted to get some opinions, because if I have to pay to get this fixed, I might as well get some quality gaskets and bolts on so it doesn't happen again.
What are your average Ford repair bills for this sort of surgery? My dads Ford motor guy that works at a stealership said $3000-4000 ...
Thanks in advance guys,
-J
What if I really was in distress ?????? Immediate ????
Might as well keep searching the forum ...
Thanks,
-J
Old Jul 4, 2010 | 04:43 PM
macaw's Avatar
With the problems ford has had out of the 6.0 I would say A cracked head. You might get lucky but I wouldn't bet on it.
Old Jul 4, 2010 | 11:09 PM
matt w.'s Avatar
Default EGR cooler is cracked.
Almost positive. See it all the time. Pull your egr valve and look in the intake manifold. Is there moisture in there? If so cooler is cracked for sure.
Old Jul 6, 2010 | 06:48 PM
NoMo6.0's Avatar
Default Egr cooler
It sounds like you egr cooler.Do ya have the egr delete kit?If not id start with the egr cooler first before you tear into the head.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
caissiel
Sep 24, 2015 05:37 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
HE22871
Nov 26, 2014 03:15 PM
1994cummims
9
Oct 15, 2014 11:37 AM
