clutch problems
Old Jun 26, 2010 | 12:00 AM
viddycent's Avatar
Default clutch problems
guys need some help.... the other day i was driving around and i went to shift and my clutch stayed on the floor no pressure to kick it back and i was wondering if it could be that way becausde there is air in the system or what and if so where and how do i go about bleeding the system. or what else can be wrong with this.
Old Jun 26, 2010 | 10:43 AM
Duckslayer74's Avatar
Did your accuating rod fall off your clutch pedal? Could be your master cylinder and slave cylinder going bad, if thats the case buy a prebled kit to replace them. What clutch do you have?
Old Jun 26, 2010 | 11:09 AM
viddycent's Avatar
its a stock clutch. the actuatin rod is still there i was thinking it was the master cylinder because there is fluid around the area i just cant see the leak
Old Jun 26, 2010 | 05:32 PM
Change out the hydraulic system.
Old Jun 27, 2010 | 01:55 PM
dirty balz's Avatar
my old work truck had a problem like this and it ended up being a clutch issue
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
kryz9903
Jul 2, 2015 06:14 AM
klu408
Apr 26, 2015 07:52 PM
Wyocumins
Oct 19, 2014 09:34 PM
