up grades
Old Jun 24, 2010 | 08:30 PM
Kodie's Avatar
Default up grades
i would like to grind the fuel plate in my 1994 cummins but i dont know the size of the tamper proof screw.
i also read something about some kind of govener or cam thing that you can mess with right below the fuel plate can you explain please. what will it do?
i also wanted to take the silencer off my turbo and the baffles out of the tube is this a good idea? any pointers?
i want to get the most out of my stock turbo (one guy siad that he had 38 psi out of it)
is there any thing that i can do to my stock boost elbow?
are there any other things you can tinker with to improve?
sorry for the igorance.
any pointers would be a huge help!
also where are the turbo baffles?
Old Jun 24, 2010 | 09:08 PM
BIGREDGOAT's Avatar
you will probly get a better response if you post this question in the cummins 2nd gen forum man
Old Jun 24, 2010 | 09:48 PM
Moved to correct forum.
Old Jun 25, 2010 | 10:07 AM
85_305's Avatar
Being Evaluated
There isn't a size to the tamper proof screw; THEY AREN'T SUPPOSED TO COME OUT.
With that being said, grab a chisel and a hammer and turn the screw counterclockwise by pounding the chisel down on the side of the tamperproof screw.
The "cam thing" you are hearing about is a fuel plate.
The "governor thing" you hear about are governer springs which keep the truck fueling to the 3k rpm point or the 4k rpm point.
What baffles are you talking about in the turbo? I've never heard of those. The silencer ring removal will sound GOOD on it though.
There aren't any boost elbows stock on these; but you can install a boost elbow and run about 35psi on the stock turbo.
Old Jun 25, 2010 | 09:42 PM
dan33klein's Avatar
pound a t 25 torx bit in the tamper proof screw and it will come out
are you referring to the grid heaters as baffles?
Last edited by dan33klein; Jun 25, 2010 at 09:42 PM. Reason: Automerged Doublepost
Old Jun 26, 2010 | 11:17 PM
Kodie's Avatar
okay i took the turbo silencer out and ground down the fuel plate the turbo sounds great and the coal rolls !!!
some one told me that it would mess up the injecters though is that true?
Old Jun 27, 2010 | 01:33 AM
angelic0-'s Avatar
The baffle, do you mean the tube on the airfilterbox ? i took mine out... made deeper sound and more whistle
Old Jun 27, 2010 | 01:41 AM
tltruckparts's Avatar
no it wont mess up injectors
Rockin-coal-01
Jan 13, 2015 12:31 PM
