Front brake help
Old Jun 19, 2010 | 05:33 PM
npccpartsman's Avatar
Default Front brake help
I'm posting this for a friend as I have no clue about the new dodge trucks. I need some help from DODGE EXPERTS.
My friend has a 2001 1500 with less than 50K miles. He only drives it 10 miles to work and back daily. Problem is that he's already replaced the front brakes twice and is in process of doing it again today. Rear brakes have already been replaced too but they weren't worn out.
Is there a cure or is it just crappy brakes and the system needs an upgrade. He's on his way to have the rotors turned as I type this. He says the truck stops really well it just eats pads like crazy. The caliper pins aren't rusty or corroded and the pads are wearing very evenly. Truck doesn't pull one way or the other and the brake fluid was recently changed even though it was very very clear.
Old Jun 19, 2010 | 06:29 PM
Pretty much normal.
Old Jul 7, 2010 | 04:11 PM
mkostersitz's Avatar
Maybe he should look into a Jake/Exhaust brake Saves a little on the break pads. At least it did for me
Old Jul 7, 2010 | 05:03 PM
van's Avatar
van
Default van
Buy the best braske pads that you can get. You may want to check the calipers.
Old Jul 7, 2010 | 05:13 PM
tiremann9669's Avatar
Are the rears adjusted up or is the guy just runnin on his front breaks ?
Old Jul 7, 2010 | 05:16 PM
van's Avatar
van
Default van
I had trouble with a 1991 and I replaced the calipers even though they did not seem bad and my brake problem got a lot better.
Old Jul 7, 2010 | 05:52 PM
trynto's Avatar
The way a person drives has alot to do with how long brakes last...
Turbo67
Jul 25, 2015 02:26 PM
corksil
Jun 30, 2015 06:58 AM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
