my cummins won't start hot!!! I need to fix it!!!!!!!!!!!!
Old Jun 18, 2010 | 09:47 PM
skocpohlave's Avatar
Default my cummins won't start hot!!! I need to fix it!!!!!!!!!!!!
I have 2004 cummins 5.9l and I can't start it when its hot. no codes no check engine. I need step by step instructions how to fix it. I am not an mechanic but with a little help ....
Old Jun 19, 2010 | 02:35 AM
RamHD's Avatar
Whats it doing when you turn the key ?
Old Jun 19, 2010 | 08:30 AM
Everything is as is supposed to be all lights will go on than when its hot its cranking but it won't start, but when its cold like in the morning it will start right away.
Old Jun 19, 2010 | 10:25 AM
You say there are no codes. Have you used an actual OBDII scanner on it?
Old Jun 20, 2010 | 09:27 AM
I had it in mechanic shop and they sad no codes are on. can't tell more
Accubuck
May 7, 2015 04:46 PM
mcclusk
Feb 21, 2015 09:50 PM
trab123
Feb 9, 2015 09:44 AM
rschriek
Jan 26, 2015 07:30 AM
Downd19
Dec 30, 2014 02:49 PM
