6.9L & 7.3L Performance Discussion of 83-94 6.9 and 7.3 Liter Ford Diesels Related to Performance and Longevity
lift pump
Old Jun 14, 2010 | 08:14 PM
86F2506.9,77F2506.6's Avatar
Default lift pump
what psi does the lift pump put out
Old Jun 24, 2010 | 08:30 PM
poocher pup's Avatar
thinking about 5-8 lbs, but could be wrong. it is low,more volume than pressure
Old Jun 25, 2010 | 09:15 PM
Hyde's Avatar
Probably more like 2-3, just to feed the transfer pump in the IP
Old Jun 26, 2010 | 10:45 AM
Sycostang67's Avatar
The stock lift pump puts out 4-5psi, you can go a bit higher, about 7psi I believe. You dont want to go much higher though as the increased pressure will throw off the timing in your IP and possibly blow out some seals.
Old Jun 27, 2010 | 01:30 PM
cowboyford16's Avatar
how would you crank the pressure up? and just doing that means your throwing more fuel tyo the IP right?
Old Jun 27, 2010 | 11:51 PM
You cant adjust a factory lift pump, but a lot of people switch to electric fuel pumps that are adjustable.
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
