2003 cummins stalling when a load is applied
Old Jun 13, 2010 | 03:39 PM
jaw's Avatar
jaw
Default 2003 cummins stalling when a load is applied
hey, guys the proublem i am having is my 2003 dodge is wanting to die when i take off from a trafficlight . This proublem is intermitant, also when the truck is idleing in the driveway every few seconds it develops what sounds to be a fuel knock and the fuel pressure will drop 5-10 psi and then recover. can someone please help?
Old Jun 13, 2010 | 07:52 PM
turbo20psi's Avatar
Sounds like the lift pump,or air getting in the line.What type of lift pump you have?
Old Jun 14, 2010 | 08:53 PM
jaw's Avatar
jaw
i have a raptor lift pump witch was only instaled about 6 months ago
what kind of fuel psi should i be running my pump was set at 15to20 psi i just uped it to between 30 and 40 psi ??
Old Jun 14, 2010 | 09:08 PM
crzycummins's Avatar
15 psi is about right for idle...are you running gauges?
Old Jun 14, 2010 | 09:30 PM
Red_Rattler's Avatar
High Tech Redneck
30-40 is too much for a stock cp3 Mines set to 25 max
Aug 13, 2015 11:50 AM
Mopar92
Mar 11, 2015 09:17 PM
elkmaniac
Oct 29, 2014 07:01 PM
Oct 24, 2014 04:40 AM
dieseldude03
For Sale
Oct 2, 2014 07:53 AM
