Clutch
Old Jun 9, 2010 | 03:59 PM
dirtydeeds07's Avatar
Default Clutch
I am not sure what is happening with my psd and need some help. It is ungodly hard (think pushing/pull as hard as possible with no succes)to put it into gear. but on 1st, 2nd and reverse. there is no slippage while driving just hard to shift with those gears. no grinding or poping back out either. any ideas???????
reason for asking is that i am afraid itl get to the point to where i wont b able to use those gears o shift.
Old Jun 9, 2010 | 04:30 PM
12vcummins96's Avatar
sounds like you need to bleed your slave
Old Jun 10, 2010 | 01:42 PM
okk never thot bout that how do you do it posibly a dumb question but idk
Old Jun 11, 2010 | 11:14 AM
cfarley0210's Avatar
ya it sounds like its got air in the line. if its a huydraulic clutch? if its a external slave cyl there will be a bleed screw somewhere on it next to the hydraulic line. also bleed your master clutch cyl. it should be about the same way. they need to be done like brakes so you will need another person to help
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
lmshowalter
5.9L 24V Performance
Jul 16, 2015 06:39 PM
Dozey
Mar 5, 2015 01:49 PM
Wyocumins
Oct 19, 2014 09:34 PM
