Help No Idea what has happened!!!!!
Old Jun 8, 2010 | 06:37 PM
ruwired's Avatar
Default Help No Idea what has happened!!!!!
Need Help! I have a 1994 Ram 12Valve. For the past several months have had problem with rough idle. Replace injectors with stage 2's. More power afterward but still rough idle an no power till around 50 MPH. I moved plate an afc full forward seemed to help with power but seemed like it was starvn for fuel. Replaced lift pump 3 days ago an finally a little smoke but still rough runnin . Well truck had been sittin sence yesterday so I took fuel heater off an trashed thought maybe suckin air. Well started primin an was hearin air leak behind Injection pump. Well I found that the stamped steal plate coverin lifter tappets looks like someone took a prybar to it an bent it out. Anyone have any Idea WTF happened.
Old Jun 8, 2010 | 06:43 PM
mikmaze's Avatar
does it look like its bent from the inside out ? sounds like parts trying to move out of ............ Dodge !
Old Jun 8, 2010 | 06:44 PM
12vcummins96's Avatar
sounds like you got a bent push rod
Old Jun 8, 2010 | 07:00 PM
ruwired's Avatar
I can't see into the block like I said looks like its been pryed out at the corner. Damest thing I have seen no bang or pops just realy rough Idle when I shut it off yesterday.
Walker.B
Chevy/GMC Duramax 01-04 LB7
8
Nov 12, 2015 09:00 PM
Grat124
Jun 3, 2015 01:46 AM
Joel Steven
Nov 16, 2014 05:49 PM
