lb7 surging at idle
Old Jun 6, 2010 | 02:01 PM
lb7 doctor's Avatar
Default lb7 surging at idle
replaced the cp3 with a new industrial injection 42%pump now the truck surges at idle and i cant keep prime at filter housing need some help please
Old Jun 7, 2010 | 12:25 AM
2500HeavyDuty's Avatar
do you have a lift pump on the truck?
with a moded pump on a stock truck it can surge at idle there will have some recalibrations that have to be done.
check for leaks at the filter housing also
Old Jun 7, 2010 | 06:33 AM
lb7 doctor's Avatar
yes have a fass 150gph !
when i first start the engine it idles great for about 5 seconds thn surges
I have a new o-ring kit ordered for the filter housing also
Old Jun 7, 2010 | 11:14 AM
Turbo Performance's Avatar
O ring kit should solve the prime issue, but a good percentage of guys who put on modded pumps have to tune the surge out.
Old Jun 7, 2010 | 11:55 AM
yup, if you have a problem surging monitor your rail pressure at idle with efi live, if you have it
Old Jun 7, 2010 | 11:29 PM
lb7 doctor's Avatar
dont have efi live yet
im also getting a p0089 code which is fuel pressure regulator code but the pump and reg. were both new
Old Jun 8, 2010 | 06:28 PM
Probably getting the code due to the pump. If the computer is seeing irregular pressure and is trying to account for it with the regulator it's probably popping the code thinking something is wrong. Sounds to me like you need to tune idle pressure with EFILive or call whoever's programmer you're running and see if they'll tune for the larger pump.
Old Jun 9, 2010 | 11:51 AM
lb7 doctor's Avatar
just got a new regulator from industrial put it on and no diffrence still surges at idle im begining to think im not getting a signal from somewhere to tell the regulator to open
john grossman
10
Jan 12, 2019 08:58 PM
duramaxtuner
LB7 Performance
9
Aug 5, 2015 11:36 PM
cdetterer
15
Dec 8, 2014 08:46 PM
DanielC559
8
Nov 21, 2014 06:59 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
