clutch issue
Old Jun 2, 2010 | 08:26 PM
94cummins12v's Avatar
Default clutch issue
ok when i did my ford cummins conversion i put my 94 cummins in a 91 f350. ford cummins told me to use the ford master cylaner and clutch line with the nv4500 slave cylandar which is what i did. took it on a trip last weekend the clutch has to go all the way to the floor to disengage. when letting the clutch back out maybe 3/8" the clutch grabs. and after 2 days the master cylander would be empty. any idea?
Old Jun 2, 2010 | 09:23 PM
12vcummins96's Avatar
i would check that crappy master cylinder they are stinkin plastic junk
Old Jun 3, 2010 | 07:43 AM
ok that still dont help me at all because the master cylander that dodge uses is also plastic as is the hd version southbend and valair sell so i can tell ya that the plastic isnt causing it
Old Jun 5, 2010 | 05:13 AM
Valair1's Avatar
FormerVendor
you definetly have a leak, do you see any fluid or a wet spot somewhere.
Old Jun 5, 2010 | 10:17 AM
off the top of my head no everytime i fill it it drips i can take a look with having someone pump it to see if i can see anything
Old Jun 5, 2010 | 11:17 AM
Valair1's Avatar
FormerVendor
I'd look where the lines go in to the cylinders, its got a o-ring there.
Old Jun 5, 2010 | 04:07 PM
ok i did some inverstigating no fluid leaking around the slve but there is soom around were the line conects to the mastercylander, i put the new o-ring on the line o bought from ford when i did the conversion
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
ford_man
Feb 21, 2015 10:59 AM
es772
Oct 23, 2014 08:29 AM
Wyocumins
Oct 19, 2014 09:34 PM
