Replaced head gasket, Now weird squeel
Old Jun 2, 2010 | 04:59 PM
rkadcock's Avatar
N.M. Bombers Director
Default Replaced head gasket, Now weird squeel
I replaced my headgasket and did headstuds on my 97 last night, and we wrapped it up this morning. When I went to start it, the is a loud squeeling noise which seems to be coming from the driver side of the engine. All the rockers are moving when I crank but I don't want to turn it over while their is that squeak because the last thing I need is to damage something. I also tried turning the engine over with the alternator nut and all it is doing is slipping the belt and nothing is turning. But when I try starting it, it's the complete opposite. I would really like to get this fixed ASAP so I can drive my truck again
Old Jun 2, 2010 | 05:23 PM
12vcummins96's Avatar
did it start up
Old Jun 2, 2010 | 05:44 PM
rkadcock's Avatar
i haven't started it up yet, just because that squeel and I don't want to mess the enigine up. I'll upload a video of it here in a minute so you guys can hear what it sounds like
Old Jun 2, 2010 | 05:51 PM
cool
Old Jun 2, 2010 | 06:08 PM
rkadcock's Avatar
Old Jun 2, 2010 | 06:23 PM
sounds like you have a compression leak did you mess up the gasket somehow or you got the valves way to tight
Old Jun 2, 2010 | 06:27 PM
rkadcock's Avatar
The gasket is good, I know that. I'll try adjusting the valves. I know when I was doing the pushrods, a few of them gave me some trouble but I didn't force them and they eventually went in
Old Jun 2, 2010 | 08:02 PM
AF1CUMMINS's Avatar
Was there anything wet under the hood when you tried to start the truck? I swear it looked like a few drops of water shot out on the turbo side of the motor on the first crank.
Old Jun 2, 2010 | 09:25 PM
i saw that to hmmmmmmmm
Old Jun 3, 2010 | 03:14 PM
rkadcock's Avatar
i think the valves are to tight, but I haven't got to check it out yet. The spray was from my injector tube. It was still loosened from bleeding the lines
