2002 dodge no start
Old Jun 2, 2010 | 09:43 AM
ffemt44169's Avatar
Default 2002 dodge no start
My 02 Ram 3500 shut off with no warning when I clutched it at a stop sign and would not restart. I just installed a 150gph AirDog pump about a moth a ago and am still getting 15-18 psi at the pump. It will try to start but just "chug" for a few sec. and blow black smoke then shut back off. Is it the injection pump bad or do I have another problem, thanks
Old Jun 2, 2010 | 01:22 PM
Have you scanned for codes?
Old Jun 2, 2010 | 04:02 PM
ffemt44169's Avatar
cannot get my solus to comunicate with it or anyting else right now, gotta see the snap on man on monday
Old Jun 2, 2010 | 04:15 PM
Have you tried cycling the key on/off three times and watching the odometerer window?
I dont trust it but its worth a shot...and doesnt cost anything
Old Jun 7, 2010 | 08:30 PM
ffemt44169's Avatar
no codes so far, bled the lines and got it started, ran for a day, then shut off again, but only during heavy throttle. Checked the lines and all are tight and dont appear to be leaking
Old Jun 7, 2010 | 10:21 PM
Dead pedal or shutting off under heavy acceleration could be the injector pump.
Old Jun 13, 2010 | 06:33 PM
jaw's Avatar
jaw
I think it sounds like the injection pump
Old Jun 18, 2010 | 03:39 PM
Cain379's Avatar
i had the same problem at one time and it turned out to be the solenoid that controls the lift pump. I put a new one in and haven't had that problem since.
Mac1997
Jul 13, 2015 05:08 AM
PeteBug
5.9L 24V Performance
May 23, 2015 01:17 PM
rschriek
Jan 26, 2015 07:30 AM
Dec 29, 2014 10:20 AM
elkmaniac
Oct 29, 2014 07:01 PM
