1996 c3500 electrical problems
Old May 19, 2010 | 10:40 AM
greene1564's Avatar
Default 1996 c3500 electrical problems
I have a 1996 c3500, 6.5 turbo diesel, I am having trouble with a few electrical acc. the radio, the wipers and the ac and the heater motor all quit working at the same time. I checked the fuse box in the dash and I am not getting power through those circuits but the fuses are not blown. any ideas would be appreciated.
Old May 19, 2010 | 01:03 PM
the_new_kid's Avatar
Have you checked any of the main fuses in the engine bay. Could also have a worn through wire with a truck of that age too. But I would check in the wngine bay for a blown fuse.
Old May 19, 2010 | 01:11 PM
ArizonaRedneck's Avatar
could have a fusible link that is bad
Old May 19, 2010 | 09:57 PM
2MuchJunk's Avatar
Do they still run fusible links in 96? I think my 95 has resettable relays. Which if it does it would be the same thing you are thinking. Not for sure just don't remember seeing links on it.
Old May 19, 2010 | 10:26 PM
greene1564's Avatar
Thankyou all for your sugestions I had check all the main fuses in the engine bay but decided to take a second look and on the igtion b fuse there was some corrosion on the block I had too look real close to see it after some alcohol and a qtip cleaning everything is back to working order and thanks again for the suggestions
Sam
F1nch
Mar 24, 2015 12:15 AM
rajdiesel
Mar 14, 2015 07:11 AM
