Off Roading Diesel Discussions of Off Roading , Set Up , Designs , Practices , Techniques , Tips Including Trail Riding , Rock Climbing , Mud Bogging And More
Winch question
Old May 19, 2010 | 12:19 AM
92_cummins_f250's Avatar
Default Winch question
So I can get a pretty good deal on a Warn 8274 from a good friend of mine, I don't think it's quite rated heavy enough for my truck, but I also know those 8274s have a very good reputation for being tougher than they are rated for. I'm not going to be using it every weekend or winching 8 different trucks up a tough trail, more for when I do something stupid or get in trouble in the woods or to winch a log or deer, stuff like that. I already have a ****** block, which I know really helps and an extra 76' of 3/8" cable. I'm not sure what my truck weighs exactly yet, going to go weigh it by this weekend. I tried searching for some info about 8274s on fullsizes and didn't come up with much, was wondering if anyone here had any thoughts, info or experiences with something like this.
Old May 19, 2010 | 03:37 AM
96dodgeplayer's Avatar
how much is the warn 8274 rated for?
8274 pounds?
if so then if you get stuck it wont pull you out. a good rule to go for is,
1 + .5 your truck weight = winch rating to get.
i have a 78 half ton that an 8k winch wont barely move it if i get stuck, i switched to a 12k winch and wow. love it.
but i would def get a warn winch! i spent more replacing my cheap winchs then buying a new warn!!
since you dont know your truck weight just take a close guess
i would just say prob no more then 7k with just you in it.
so that would be 7000 + 3500 = 11000 pounds winch rating to be safe.
mud makes your truck weigh much much more
Last edited by 96dodgeplayer; May 20, 2010 at 03:18 PM. Reason: Automerged Doublepost
Old May 19, 2010 | 08:40 AM
stevenbrazell's Avatar
weight should be on the door panel.
Old May 20, 2010 | 12:42 PM
DieselCrawler's Avatar
thats gvwr. not curb weight. plus his insnt stock engine. i would guess it in around 7500 lbs. i know my 86 weights in around 6500. u got more cab then me so little higher.
PA 24valve
Aug 31, 2015 06:08 AM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Down South
Jan 11, 2015 01:33 AM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
