tranny help
Old May 13, 2010 | 03:55 PM
smoking62's Avatar
ATTN tranny help
i have a 700r4 behind my 62 well it started leaking atf out of the cooler line so i fixed it next thing i know it wouldnt move one morning i put atf in it and it moved. it leaks pretty fast. it runs out from above the starter. and one time it filled my air filter top full of fluid i think i over filled it that time please help it looks like it comes from the top im not sure though
Old May 15, 2010 | 01:27 AM
2MuchJunk's Avatar
Sorry it has taken so long to respond but I have been trying to figure this one out. Does the trans slip? Is the fluid running out of the dip stick tube? I can't remember if the 700 has a vacuum modulator on it.
Old May 16, 2010 | 03:38 PM
smoking62's Avatar
it was spitting out of the fill tube but i could have overfilled it. and yes it slips so bad it wont go up hill if i let it sitt for too long , i dont know about the vaccum modulator
thankx
Old May 16, 2010 | 06:10 PM
2MuchJunk's Avatar
I would say you are boiling the fluid out of the dipstick tube.
Old May 18, 2010 | 09:53 AM
smoking62's Avatar
i didnt know you could boil it out how is that
Old May 18, 2010 | 10:24 AM
12vcummins96's Avatar
when a tranny is slipping it gets the fluid hot if your cooler is clogged up with friction material it will not get properly cooled so it will get hot and start to boil
Old May 18, 2010 | 05:24 PM
2MuchJunk's Avatar
X2
Old May 25, 2010 | 10:28 PM
smoking62's Avatar
how do you un clog the cooler
Old Jun 6, 2010 | 10:11 PM
87-6.2's Avatar
take both lines off of the transmission, then get an air gun with a jet tip on it and blow into either one or both and see what comes out...and just for reference there isn't a vaccume modulator on a th700r4.
Old Jun 16, 2010 | 04:11 AM
smoking62's Avatar
any body have a guess
InheritedDiesel
Jun 3, 2015 09:39 PM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Trevlar11
Nov 16, 2014 01:59 PM
