7.3 smoking and skipping REAL BAD!!
Old May 10, 2010 | 08:48 AM
smokincummins92's Avatar
Default 7.3 smoking and skipping REAL BAD!!
Hey guys I have a 99 ford 7.3 in the shop that has a big problem! When it came in here the guy told me that the truck hasnt been runin right for a while now (loss of power and what not) and he was goin down the interstate the other day and the truck wouldnt run over 35mph!! Well the truck has a really bad miss in it and it is smoking like a freight train!!! The first thing I noticed when I got in the truck was that the water in fuel light was on. So I asked the owner how long that had been on and I got this answer...O thats been on forever!!!!!! OMG!! So I pulled the fuel filter out and the inside of the boil looked HORRIBLE!! So I cleaned it and put a new fuel filter in it. The water in fuel light went out but the truck still runs the same if not worse!!! I thank he got an injector what do yall thank?? O and its blue or gray smoke!
Old May 10, 2010 | 10:24 AM
CSIPSD's Avatar
Sounds like an injector, or he dropped a injector nozzle, in which case I would bet he kept driving it and now has a cracked piston...
does it have excessive blow by?
Old May 10, 2010 | 10:49 AM
Yes it does have some blow by. When you take the oil fill cap off it just puffs smoke. What is the best way to tell which cylinder is missing? I dont have a real fancy computer to tell me
Old May 10, 2010 | 11:05 AM
CSIPSD's Avatar
You need a scanner to do a cylinder contrubution test... Otherwise its going to be near impossable to fine it.
Old May 10, 2010 | 11:12 AM
Lange503's Avatar
mine did the same thing, i barely made it home when my injector went out, also check the IDM, that went out in mine also, caused a misfire in the #4 cylinder, which is the same cylinder the injector went out in, hope this helps
Old May 10, 2010 | 12:55 PM
Yea thanks guys I appreciate it!!!!
