2nd Gen Down
Old May 9, 2010 | 12:27 AM
jasonfriedlin's Avatar
Default 2nd Gen Down
So I am postin for my buddy Bullrider 96 cuz he says the internet no work in Mexico. Anyway he's got a 96 2nd gen and says its hard to start and will only rev to 2000 rpms. I told him it sounds like the lift pump but figured I'd ask you fellars for him too. He said it will start just not easy and doesn't run good at all. Any ideas are appreciated.
Old May 9, 2010 | 12:31 AM
ArizonaRedneck's Avatar
he's actually in mexico what about fuel filter and like you said lift pump fuel filter first and maybe while he's down there a little fuel additive
Old May 9, 2010 | 12:34 AM
12vcummins96's Avatar
filter or pump
Old May 9, 2010 | 12:40 AM
Nor_Cal_Angler's Avatar
Is it posible for you to post more info about his truck....what are we working with here...symptoms are one thing but we need more about the truck...
any guages..big one being FP..if so whats it showing when truck is cranked and once its running.
how long ago did the filter (fuel) get changed
did he get bad fuel...
how old is the lift pump...
is it the stock lift pump or aftermarket...
could air be introduced from somewhere...fuel line crack or maybe fuel filter...
hows the voltage to the lift pump...
is the truck BOMBED???? different injectors/injectors fouled...
just need more to go on....the question is straight forward but the answer could be hard or easy depending on some background info.
NCA
Old May 9, 2010 | 01:00 AM
He's not really in Mexico, just New Mexico. The truck is a 1996 12 valve, 3200 spring, stock lift pump, all gauges except fuel pressure, fuel plate adjusted for more power, 5 speed. I cant think of anything else, don't know when the fuel filter was changed last but i think he said it came on all the sudden. All the diesels I've driven and stopped up fuel filters Ive had, Ive never seen one make it hard to start so I doubt he's that lucky. I told him to try to check the fuel pressure. Im still bettin lift pump. Hopefully he will get back to civilization with internet, he can tell you more than I can. Thanks for the help
His truck info is in his sig found here in his "About Me" section
https://www.dieselbombers.com/members/bullrider96.html
Last edited by jasonfriedlin; May 9, 2010 at 01:01 AM. Reason: Automerged Doublepost
Old May 9, 2010 | 01:03 AM
fuel filter 1st the easiest and fastest way to count that part out and then you know
Old May 10, 2010 | 05:32 PM
bullrider96's Avatar
Aright i finally found some internet and im not in mexico guys just that hillbilly is jealous cause im better than him. Anyway i changed my filter and it haelped a little bit but not perfect yet. I starts hard like in the mornings but its not even cold and even sitting for like two to three hours it will still start hard to i dont know i just dont know!
Old May 10, 2010 | 05:41 PM
Ever changed your rubber fuel lines? Sounds like your losing prime.
Old May 10, 2010 | 09:07 PM
Caposa homes. It sounds like you might be getting some air in the system maybe.
Old May 10, 2010 | 09:31 PM
yep could be losing his prime and what about the good ole trusty fuel pressure gauge could help explain a little better
