3k govenor springs
Old May 8, 2010 | 07:16 AM
spetersen502's Avatar
Default 3k govenor springs
how much time would this take like an hour or two just wondering and its just on the side of the pump just turn it over right
Old May 8, 2010 | 07:24 AM
cummins95's Avatar
for your first time it should only take maybe an hour n a half. it took me that long because i was extremely cautious getting the shims out, but it really isn't that bad. pull the plug out of the side of the pump, replace 1 side, then roll the motor til u see the other spring n change it. what kit did u get? it should have instructions with it.
Old May 8, 2010 | 10:03 AM
Instructions:
PDR governor spring installation
Old May 8, 2010 | 11:38 AM
12vcummins96's Avatar
well doc you beat me to it
Old May 10, 2010 | 01:04 AM
96dodgeplayer's Avatar
Old May 13, 2010 | 04:16 PM
Threesixty's Avatar
Originally Posted by Dr. Evil
Those instructions are to go thru the top, If you read further down there are some more instruction of going thru the side.
Also, there is a discussion here that also has written instruction of going thru the side....
I've yet to try it myself, but I will, eventually.
https://www.dieselbombers.com/5-9l-1...springs-2.html
I suggest buying 2 heater grid gaskets, before you attempt it though....
Old May 13, 2010 | 11:18 PM
when you buy the kit it comes with instructions. to go on the side
Old May 14, 2010 | 12:06 AM
12valvetater's Avatar
Just for your information. Not all pumps have shims under the springs.
Old May 15, 2010 | 04:32 PM
relay93's Avatar
Or the same amount of shims on both sides.
Old May 15, 2010 | 04:47 PM
biged681985's Avatar
i thought all of them had shims from the factory just make sure there isnt any in there, there kinda hard to tell if theres any in there, they stick to the bottom of the barrel
