Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
2008 6.4 Diesel Problems
Old May 5, 2010 | 12:31 PM
Brad Tampa's Avatar
Default 2008 6.4 Diesel Problems
We have a 2008 6.4 in a F-350 crew cab ford. The stats:
76118 miles vin# 1FTWW31R18EA45177
Have replaced radiator 5 times , vehicle overheated badly each time
Last time vehicle overheated batteries exploded, ford checked charging system, Ford said charging system operating properly.
Ford removed and replaced fuel pump
Ford removed and replaced crankshaft oil seal / leaking
Ford removed and replaced oil pump
Last week oil light went on, no oil pressure / towed vehicle in / Ford declined warranty due to sludge buildup in engine
Have given Ford oil change information, Dealers changed oil 3 times and owner changed oil 4 times.
Ford never changed or flushed engine even after all the overheating events, should they have ??
Would overheating engine cause oil breakdown and heavy sludge deposits in Valve covers and on top of cyclinder heads ?
Please help us.
Last edited by ArizonaRedneck; May 5, 2010 at 01:45 PM. Reason: moved here sounds like a tech question more than a potential diesel owners question 1st post need to go to the intro forum and introduce yourself
Old May 5, 2010 | 02:56 PM
SD207434's Avatar
have you looked into the lemon law? Do they have a lemon law there?
Old Jul 19, 2010 | 02:49 PM
tkeaton's Avatar
we have a 08 6.4 have had nothing but trouble with it this time it has been in the shop for 8 weeks for the 4th short block very unhappy with ford at this time was told it didnt fall in the lemon law because of the size
Old Jul 19, 2010 | 03:32 PM
gunman41mag's Avatar
Moderator
Please help us.
I would call the FORD HEADQUATERS & complaint about all the problems you have had, Call a LAWYER if FORD is playing games with you !!!
Old Jul 26, 2010 | 06:41 AM
Brad Tampa's Avatar
Default 08 Ford 6.4 Update
Since our last post we got an oil sample analyized by a lab in South Florida
The results are as follows: (in parts per million)
Aluminum 33
Chromuim 12
Copper 40
Iron 225
Lead 83
Tin 12
Silicon 10
Potassium 24
Sodium 525
Moly 9
Water 0.4
Oxidation 30.9
Viscosity 16.8
Glycol nd
Fuel <2.0
TBN <3.0
Soot 350
The lab said that the egine was comprimised (head gasket, cracked block) that introduced water / anti freeze into the oil during one of the overheating events.
Ford said the oil analysis is normal
Ford will not fix truck
Old Jul 27, 2010 | 06:31 PM
Moderator
It's time to get a L A W Y E R
Old Jul 27, 2010 | 06:40 PM
BlackCloud96's Avatar
Ill let you borrow my desert eagel 50 cal and i think they will change their minds!!!!!!!!
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Macster86
Jul 21, 2015 09:23 AM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
