where to run mechanical oil gauge to
Old May 3, 2010 | 09:55 AM
96blackcloud's Avatar
Default where to run mechanical oil gauge to
where should i run a mechanical oil pressure gauge to? is there a port or anything like there is for the boost lines?
Old May 3, 2010 | 10:03 AM
jumpnjed's Avatar
My factory gauge in the dash went south on a long trip to Tennessee in feburary. I looked down at the gauge and there was no oil pressure at all ... I quickly pulled over and found a Oreily auto parts and bought a mechanical gauge and installed it in the parking lot and whala over 60#s of oil pressure. There is a port on the top of the oil filter housing where i run mine to. It worked out perfect there...
Old May 3, 2010 | 01:07 PM
that is exactly what has happened to me looked down no pressure everthing was running cool and plenty of oil just couldnt find a place to tie one into thanks
Old May 3, 2010 | 01:11 PM
jumpnjed's Avatar
No problem man.. Let me know how it works for you... I just need to find a place to mount the gauge. I already have three gauges on the pillar but havent figured out where to mount the oil pressure gauge..
Old May 3, 2010 | 01:30 PM
12vcummins96's Avatar
well got that one handled
Old May 3, 2010 | 03:37 PM
i found the perfect place to mount mine i just did a auto to manual conversion and the place in the dash were the O/D switch was is just big enough to dremel a hole out and slide in the gauge.
did you have to get a nipple to screw into that port or additional hose or did it all come with the gauge?
Last edited by 96blackcloud; May 3, 2010 at 03:37 PM. Reason: Automerged Doublepost
Old May 3, 2010 | 03:55 PM
jumpnjed's Avatar
The nipple cam with the gauge. If i ant mistaken is a 1/4"npt niple. It didnt come with much hose so you may need a longer piece it just all depends on your routing and where you are gonna put the gauge.
Old May 3, 2010 | 04:33 PM
Oil is fed from the second port on the oil filter head to the guage. The fitting is 1/8" npt.
Old May 3, 2010 | 07:04 PM
thanks guys, thanks the pictures really helped clear up where it was.
Old May 3, 2010 | 07:19 PM
Dont forget a ball valve in case the guage leaks (and it certainly can) - you can shut it off quick. 70 psi of hot oil = not good.
