2001 250 wont start
Old Apr 29, 2010 | 04:21 PM
spetersen502's Avatar
Default 2001 250 wont start
I got a 2001 ford and it wont start replaced the camshaft sensor and there is no fuel leak cleaned the Exhaust Back pressure line so the only thing is I don't know what's next my map sensor is reading 90-97 is that to much or to little
Old Apr 29, 2010 | 04:34 PM
12vcummins96's Avatar
whats your fuel pressure your hpop pressure all those are considerations
Old Apr 29, 2010 | 05:26 PM
wmorrispilot's Avatar
Default inj pressure while cranking
this needs to get real close to 450 on the scanner before it will start. First thing is scanner on it while cranking to check this. If you do not have a scanner then go ahead and pull the plug on the upper high pressure oil pump housing.... Make sure the oil level is not more then one inch below the plug. If it is too low. fill with oil and it will more than likely start.... somethings to try......
tntmechanic
May 18, 2016 04:59 AM
tim12valve
Apr 27, 2015 11:42 AM
ronstop
Feb 26, 2015 09:48 AM
rschriek
Jan 26, 2015 07:30 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
