Getting A New 12V - Need Help With Build Up
Old Sep 16, 2007 | 07:39 PM
Monster Truck's Avatar
Default Getting A New 12V - Need Help With Build Up
Hey guys Im going to be getting a 12v in about a month. I want to start planning out the bombs. Id like to do 400-450 hp and 1kfoot lb. It will be a everyday driver a 5spd and a 215 pump. I need to be able to tow but no plans on big time towing just around 8k.
Thanks for the help in advance. MT
Old Sep 16, 2007 | 07:48 PM
DB Admin's Avatar
Banned
Sounds like a Great Plan George !
Old Sep 16, 2007 | 08:03 PM
Thanks boss man. Anybody have a good bomb list for 400hp?
Old Sep 16, 2007 | 08:48 PM
Gauges
Tranny upgrades
Turbo
Injectors
Old Sep 16, 2007 | 08:57 PM
What turbo should I go with? what sticks? 330s? what fuel plate to go with? is south bend a good clutch to go with?
Old Sep 16, 2007 | 09:01 PM
Whit's Avatar
Site Mascot
gsk 4000 w/hd valve springs 60#
cam plate #0
191delivery valves
Injectors
overflow valve
High psi intercooler boots/clamps
Modified HX35-TW/14 w/gated housing, HT3B/26
ATS 3 piece pulse manifold, complete piping kit & AFE 5" filter
13" CON FE
Built tranny
4" exhaust
Gauges
BD exhaust brake 4"
stacks
Shifter switch for BD brake
Valet switch
Head stud kit
O-ringed head
Old Sep 16, 2007 | 09:28 PM
What he said.....
Old Sep 16, 2007 | 10:06 PM
WOW I wasnt expecting nearly that many parts for 400hp. How much are the dv's?
Old Sep 16, 2007 | 10:18 PM
2001shrtbedcummins's Avatar
get some 370 injectors, 191dv's, 4kgsk, your favorite brand of turbo (62mm will work...but a 64 will be better over all, so say a 64/12) http://www.industrialinjection.com/id42.html , then exhaust, intake, a confe would do from southbend...but you will eventually burn it out a lot quicker than you would a dual disk
Old Sep 16, 2007 | 10:46 PM
Thanks buddy. Thats pretty much what I was planning. What do the 191 dv's do? and should I get stronger valve springs with the 4gsk? Should I throw a #10 plate in the mix as well?
