got the motor back together today
Old Apr 28, 2010 | 10:11 PM
drivecumminsridered's Avatar
Default got the motor back together today
i guess i will start off by saying i got my motor back together today. i lifted my head awhile back so i had to put studs in and along with that i had the head o-ringed and milled down. also while i was into it i put 60lb valve springs (im planning on putting a 4k kit in it in the next few days) and new 50hp injectors. i got it all back together and fired it up and drove it around, it is running pretty ruff and is also dogish. i guess my question is why do you guys think its acting like this? i was thinking it might be because of the new injectors and also because its been torn apart and just needs to be ran and i guess broke in and cleaned out a little but i really dont know so any input and ideas form you would be great!
sorry for the long post and thanks for the help
Old Apr 29, 2010 | 01:10 AM
jrad989's Avatar
it should be broke in just fine. sounds like a fuel problem. what injectors did you get? did get the correct washers for the injectors? did you double and triple check everything?
Old Apr 29, 2010 | 05:16 PM
85_305's Avatar
Being Evaluated
Timing might be off
Old Apr 29, 2010 | 10:04 PM
94 12valve's Avatar
check for small fuel leaks sounds like there is air in there somewhere
taweste
Aug 29, 2015 02:34 PM
tbreddiesel
Contests And Give Aways
Aug 14, 2015 02:47 PM
tbreddiesel
Jul 30, 2015 09:13 AM
tbreddiesel
Jul 21, 2015 07:28 AM
Mar 11, 2015 02:10 PM
