need help on 01 cummins
Old Apr 28, 2010 | 08:11 PM
Blue01cummins's Avatar
Default need help on 01 cummins
i have codes po606 po113 po216 po121 has anyone ever had this happen the truck is reving its self. idk if it is just the tps or is something else wrong??
PO 606 PCM PROCESSOR FAULT
PO 113 IAT CIRCUIT HIGH INPUT
PO 216 INJ TIMING CONTROL CIRCUIT MALFUNCTION
PO 121 TPS SENSOR A RANGE/PERF PROBLEM
Last edited by Blue01cummins; Apr 28, 2010 at 08:11 PM. Reason: Automerged Doublepost
Old Apr 28, 2010 | 08:18 PM
coyropin's Avatar
have you tryed to adjust you apps
https://www.dieselbombers.com/5-9l-2...s-i-bored.html
Old Apr 28, 2010 | 08:20 PM
i have not it just started happening on the way home from work.
Old May 2, 2010 | 09:56 AM
Diesel Nut's Avatar
Ok, a few possibilities -
Bad PCM
Bad VP44
Bad ECM
Bad or out of adjustment APPS
The thing that has me looking at the PCM is the 606 PCM Processor Fault
We have been seeing alot of PCM and ECM failures on 24v trucks lately. We have had 2 ECM failures in the shop in the last month.
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
