Vibration under hard accel.
Old Apr 25, 2010 | 09:04 PM
SnoMan's Avatar
Default Vibration under hard accel.
HI Guys, I have a 02 dmax 4x4, When I floor it under hard acceleration I get a vibration in the drivetrain on it i think, I was maybe thinking u joints, or ??? I took it up to 80 under hard acceleration and it started vibrating pretty good, I took it up to 80 easy and it didn't vibrate at all. you can feel the vibration in the floorboards, What do you guys think......
Old Apr 25, 2010 | 11:38 PM
DuraTitus's Avatar
Sounds like you have a bad carrier bearing.
Also if your truck is lifted you might need to shim the carrier bearing down a half inch or so.
Old Apr 26, 2010 | 05:22 AM
SnoMan's Avatar
No lift, but I will check into the carrior bearings. any other ideas? Thanks for the help
Old Apr 26, 2010 | 03:05 PM
EvilBowtie's Avatar
should check axle wrap, see if your diff is walking around under accell
My 05 had it bad !
also check the center support bearing as well.
Old Apr 26, 2010 | 09:46 PM
DuraTitus's Avatar
What did you do to fix the axle wrap?
Old Apr 27, 2010 | 06:38 PM
EvilBowtie's Avatar
sold the truck
the fix was to install traction bars though.
Old Apr 29, 2010 | 10:34 PM
SnoMan's Avatar
had a couple bad universal joints.
DC_DC41
Jul 16, 2015 09:56 PM
Blanton
Apr 15, 2015 06:29 PM
findau1
Oct 28, 2014 03:47 PM
UC Kid
Oct 20, 2014 10:06 AM
