Turbo wastegate?
Old Apr 23, 2010 | 10:18 PM
B Boyce's Avatar
Default Turbo wastegate?
You guys will pry think I'm stupid, but what exactly does a wastegate do on a turbo? I took my 98 dodge to a mechanic cause it wasn't producing much power and he got me a new banks wastegate on it. I know banks power is a good performance product so how much more power do you guys think it'll give me?
Thanks
Old Apr 23, 2010 | 10:41 PM
12vcummins96's Avatar
it alows you to regulate your boost pressure
Old Apr 24, 2010 | 03:04 PM
Deezel Stink3r's Avatar
No stupid questions here!
let me extend it a bit.
A wastegate also limits boost pressure and prevents damage to the engine due to too high boost pressures.
Some wastegates open to early and delay boost response. That means you apply a bit of boost and those lame or worn out wastegates start to open and let the boost pass.
We don't won't that!
The wastegate should be closed as long as maximum boost is reached!
Thats what the Banks unit should do.
The exchange of the wastegate or its control is a common way to achieve better turbo response.
There are many ways to avoid this early bypass malfunction.
Stiffer springs as an example. Boost controller allow you to set this wastegate opening.
The best method to control boost is via an electronic valve.
That means: if your boost controller ist set to 14.7psi, the wastegate will open at that pressure. Not one psi earlier.
In return you experience (with the right setup) a harder boost due to no early losses.
Old Dec 23, 2012 | 02:24 AM
GCC Gorilla's Avatar
I just purchased the AFE wastegate for my 06 cummins, now it really wont boost at all and runs hot.
1st day of running it after install threw up p0299 error code low boost
any suggestions on how to fix this?
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
