Injector?? I am conf!
Old Apr 20, 2010 | 11:42 PM
polarcat71's Avatar
Default Injector?? I am conf!
I have a 01 3500 with 80k, all of a sudden it started to run rough and my fuel milage went to nothing, oil pressure went up and fuel and oi; started spraying and dripping all under truck.
took it in to local shop (not dealer) and they said injectors ($4,500.00). i dont have the $ (contractor and the economy s!@k's) so i took it home. I am pretty handy (very good two stroke guy! and done my fair share of gen main stuff) and going to do it myself thank to the walkthru i found on this site.
my questions are:
if one or two are bad does that mean the rest? are not far behind. change just bad ones or all? i know it is a Pain in the A!@ but am willing to save the money within reason though! if the odds are not good will go for it all.
how can you tell which ones are the bad ones? is this somthing only the dealer can do? how much will they charge just to test and tell me which ones? i already started to take apart but not to far along, will put it back and take it if i have too.
the mech shop told me the oil al over bottom of truck was just cause the oil was overfull and comming out of the overflows etc,, but doing some looking around here and maybe i blew some seals.. which is it and should i be afraid!!
can i check the injectors with a pressure guage and compressed air (90lbs) once they are out or does it not work that way..
Any help/advice will be greatly appreciated.
Joe
Old Apr 21, 2010 | 07:07 AM
2500HeavyDuty's Avatar
The work required to get down to the injectors is alot, and once your down there it only takes a little bit to do each bank of injectors after that.
You can do a balance rate test to see which one are bad sometimes, also you can check your fuel system like this: https://www.dieselbombers.com/chevy-...ssure-side.htm
to replace your injectors read over this : https://www.dieselbombers.com/lb7-bo...ips-hints.html
Old Apr 21, 2010 | 08:17 AM
WI Huck's Avatar
FormerVendor
If you take you time and are organized you can do the job. Replace all eight. The fuel in the oil is a dead giveaway that you have a bad injector. We sell all eight for under $2000.00 plus the core charge. Give me a call. I will be glad to help you out.
Mark
Old Apr 21, 2010 | 09:18 AM
polarcat71's Avatar
Mark
my only fear is if i pop out one or more of the cups. that look like a nightmare! opening up to cool leaks etc. if not done just right (simalare to base gaskets on my race sled, its only metal shim with gasket maker on it. so if its not right and put it all back together just to find a leak and take it all apart agian!!!
is there a way to insure that the cups dont come out. i will buy that Kent-moore puller if it will do this..
WI the reman injectors you have are reman from whom?? are they the ones redone by Bosch?? i was told that the remans fail (pensicola) and dont really want to do this two times before it moves a foot!
Joe
Old Apr 21, 2010 | 09:27 AM
pensacola ones are junk, dont get them.
if you do happen to pull a cup, your going to need a shotgun cleaning kit or something similar, i put a piece of scotch brite on the end of a drill and used it to clean up the mating surfaces of the sleeve and head.
Old Apr 23, 2010 | 01:58 AM
EvilBowtie's Avatar
maybe there is someone local to you that could help out?
Where are you located?
As mentioned by others. the injectors are not difficult, just a lot of bolts ... pulling a cup is not a big deal, just clean, reseal (with new O-Rings) and you are back in business ...drain your coolant first and you won't have a huge mess ...
Old Apr 23, 2010 | 08:44 AM
polarcat71's Avatar
i am in clifton park ny (just outh of saratoga)
will pulling the drain on bottom of rad drain the coolant out of the motor as well or just the rad? do i have to blow it out somehow? if so how
Joe
Old Apr 23, 2010 | 10:57 PM
EvilBowtie's Avatar
unscrewing the drain will let most of it out and you won't have an issue.
FYI -topping off will require about 4 gallons total (2 gallons dexcool, 2 gallons water)
Old Apr 25, 2010 | 04:43 PM
DuraTitus's Avatar
I agree with what everyone has said so far...
I would recommend replacing all 8 injectors while you are at it.
I have done injectors on both of my LB7's and can say it is not all that bad of a job...Just takes time!
Here is the best write up you will find on how to change the injectors yourself. https://www.dieselbombers.com/lb7-bo...tor+tips+hints
I did mine for under $1,000 in parts!
I am sending you a PM.
