Leaf spring problem
Old Apr 17, 2010 | 09:54 AM
bigworm's Avatar
Default Leaf spring problem
What kind of bushings should I relpace my old ones with?? The springs are in a 2003 HD Dodge Ram 4x4.
Old Apr 18, 2010 | 01:12 AM
ETXBlueRam's Avatar
Urethane bushings will ride a bit firmer as they flex less than rubber. They will also squeak to let you know when it's time to grease them.
Rubber will ride softer, and if your springs are as stiff as the ones on my '03 were, that's what I would stick with.
If you do decide to go with urethane, make sure you lube them with a lithium grease. Petroleum grease will break them down and make them come apart much quicker.
Hope that helps.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
2FordStrokers
Jan 5, 2015 09:23 PM
myago92
Oct 17, 2014 08:50 AM
Sep 29, 2014 03:00 PM
