6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
6.2 non turbo EGT probe?
Old Apr 6, 2010 | 07:51 PM
90dodgectd's Avatar
Default 6.2 non turbo EGT probe?
Where are you guys with non turbo 6.2's putting your EGT probe? Is there a side that runs hotter? Are you putting it in the exhaust manifold or in the exhaust? Thanks.
Old Apr 6, 2010 | 08:23 PM
2MuchJunk's Avatar
I don't know why one side would run hotter than the other. Not saying one don't though.
Old Apr 9, 2010 | 05:20 AM
90dodgectd's Avatar
Has anyone put a pyro on a non turbo 6.2?
Old Apr 9, 2010 | 11:52 AM
2MuchJunk's Avatar
I would doubt it. I wouldn't get to worried about it unless you put a turbo on it and turn the pump up then I would put on on it. Turning just the fuel up on a 6.2 without the turbo will not gain you much because on of the biggest problems with the 6.2na is they cannot get enough air.
Old Apr 11, 2010 | 08:32 PM
90dodgectd's Avatar
I just want to monitor whats going on. What if I put a probe on each side and run the wires into one and then into the gauge. Would that work? Kinda like splitting the difference, maybe. Maybe ill just forget about it .
Old Apr 11, 2010 | 09:54 PM
2MuchJunk's Avatar
I understand that. I don't know if running two sensors would split the difference or confuse the gauge. As long as every thing is stock it should be fine if you want to add a turbo or turn up the pump I would put one on it.
Old Apr 12, 2010 | 06:31 AM
ScaryFastHummer's Avatar
Yes. I have a Banks EGT guage on pyro on my truck. I put the sensor in the manifold a couple of inches from where it comes out of the head. Remember of course, that H1's have steel headers to put them in!
Works great!!
Hollie
Jan 14, 2016 01:32 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
CumminsCoalRoller24/7
Jan 29, 2015 08:37 AM
GreenDieselF
Oct 20, 2014 02:05 PM
