85chevy swb 12 valve swap!
Old Apr 1, 2010 | 08:01 PM
captain_stabbin's Avatar
Default 85chevy swb 12 valve swap!
how hard would it be to put a 94 12valve in a 85 swb truck? like motor mounts, wireharness etccc?
Old Apr 3, 2010 | 01:23 AM
tltruckparts's Avatar
search for it man. its a quite often asked question. wiring they wont make just a harness. youll either have to custom wire it, or pay someone to do it. that is if you want it to be wired right and have everything actually work. new front engine crossmember is a must with the newer motor mounts. tranny crossmember. stiffer front springs and bigger axle (unless its a 1 ton) and all that junk plus more
Old Apr 3, 2010 | 01:46 AM
sounds like funn!!! i know a guy that could do the wiring, all im worried about is the weight of the motor destroying the front end! im also concerned bout the height cause truck has a 3/4 drop!!! might bottom out!
Old Apr 4, 2010 | 07:30 AM
ironworker's Avatar
here is a place i found that has the motor mount/ cross
Avalanche Engineering - (970)884-7716 - Extreme 4-wheeling parts and accessories to complete turn key vehicless
RA113024
Mar 13, 2016 07:42 PM
savage-rider
Sep 26, 2015 12:43 PM
ReckONE
Feb 25, 2015 09:41 AM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
