6.5 turbo longblock?
Old Apr 1, 2010 | 07:20 PM
SteveinAz's Avatar
Default 6.5 turbo longblock?
Can I or should I use a turbo long block in place of a 6.5 na long block? I'm aware of the difference in compression ratio. I may put a turbo on in the future. Can I just use the short block? Is there something I'm missing? I have a 94 6.5 na in a P30 tool truck. It's all mechanical. Thx SteveinAZ
Old Apr 1, 2010 | 07:53 PM
2MuchJunk's Avatar
You can interchange both of them the difference in compression is next to nothing. The 94 p30 had a mechanical injection pump on it? Most 94 had a electronic pump on them.
Old Apr 1, 2010 | 10:15 PM
SteveinAz's Avatar
P30 even had a non turbo mechanical 6.5 in 95.
I think I have the 60* mount surface on the intake. Will my intake fit the turbo heads? Or can I mount the air cleaner to the turbo intake?
Old Apr 1, 2010 | 10:27 PM
2MuchJunk's Avatar
I forgot p30 was a van. The heads are different they have a center mount turbo and the intakes will not interchange. The heads will interchange between both of them and the lower end should be the same.
Old Apr 2, 2010 | 09:27 AM
Woody35's Avatar
go to a junkyard get some side turbo heads make sure there not cracked and you should be good.
Old Apr 2, 2010 | 04:22 PM
SteveinAz's Avatar
Are the side turbo heads 60* or 90* bolt hole at the intake?
Brclouse
Nov 18, 2015 08:44 AM
paladin1176
For Sale
Jul 8, 2015 06:35 AM
klein444
Feb 27, 2015 01:53 PM
greatlakes diesel
Feb 13, 2015 09:55 PM
Snoobly
Dec 11, 2014 11:59 AM
