white smoke
Old Mar 31, 2010 | 10:15 PM
dodge rodder's Avatar
Default white smoke
im working on a 85 6.9 turbo, it will run, idle, and sounds good, but it smokes like crazy white, and has a lot of blow-by. it dose not smell like a head gasket. what the hell is going on, has any one had this problem before. new pump, injectors, lift pump (on block)
Old Apr 1, 2010 | 12:33 AM
Sycostang67's Avatar
Did you have it timed after the pump and injectors? White smoke can mean the pump timing is too retarded.
Old Apr 1, 2010 | 12:47 AM
dieselpowermark's Avatar
hey granted mine is a GM they're both IdI's but mine blew an injector tip and it was billowing white smoke another thing WHAT KIND OF WORK HAVE YOU DONE LATELY?
Old Apr 1, 2010 | 07:23 AM
new injectors, new injection pump, new lift pump, we have been trying to get it running but my nabor is tired of throwing parts in to it. it wount start with out a little help ether . thanks for the avice
Old Apr 1, 2010 | 10:16 AM
DieselCrawler's Avatar
i would have timing checked with a tach-n-time, normally one good diesel shops will have one.
also the injectors, new from where?
Old Apr 1, 2010 | 05:25 PM
i think US diesel is where he got them.
Old Apr 1, 2010 | 05:50 PM
could also be an injector, but i am gona say it is the timing.
Old Apr 1, 2010 | 09:21 PM
Just changing the injectors will throw the timing off. The pop off pressures will be different causing the injection event to happen at a different time. Replacing the IP will also throw it off since you cant just line up the timing marks and assume it's good. The timing marks are only useful with the original unmolested IP. The new IP will be in a different spot internally so lining up the marks only gets you in the ball park.
Old Apr 2, 2010 | 02:42 AM
talked to some people and they wanted to know why he changed these parts to begin with? they said it could be down a piston or two or piston rings.
AND I DONT CARE IF IT WONT START DONT EVER PUT ETHER IN A MOTOR UNLESS YOUR RUNNING LOW COMPRESSION RACE MOTORS. HE PROBABLY CRACKED THE PRE COMBUSTION CHAMBER WITH A BACKFIRE OF ETHER. HE PROBABLY SPRAYED ETHER INTO IT AND THEN WAITED TILL THE GLOW PLUG LIGHT TURNED OFF THEN CRANKED IT AND THE SECOND HE TURNED THE MOTOR OVER IT ALLOWED O2 IN IT COMBUSTED. SO CHECK THE HEADS AND CYLINDER CROSS HATCH. THAT WILL TELL YOU HOW BAD THE RINGS ARE.
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
