Cab Lights
Old Mar 30, 2010 | 09:22 PM
svt28640's Avatar
Default Cab Lights
I bought recon cab lights for my 02 f250. It currently dont have cab lights. What am i getting into installing them. And does anyone have a link or pictures or anything about putting them on. Thanks
Old Mar 30, 2010 | 10:22 PM
Kyle_KleinSS's Avatar
I got them on mine pretty straight forward. Just make sure you mock up the holes before you drill them
Old Mar 31, 2010 | 02:57 AM
Mr. Miyagi's Avatar
Motoman's Madness
Best write-up I have found on the 'net for it...
Old Mar 31, 2010 | 12:05 PM
wesley's Avatar
ive put cab lights on my last 3 trucks and it really is simple. 1- mock up your holes . 2- remove the pillar covers and visors .3- once removed the head liner has h-d velcro right in the center at the front peel it loose then drill your holes and wire them up.....
Old Mar 31, 2010 | 12:54 PM
CSIPSD's Avatar
Originally Posted by Mr. Miyagi
Motoman's Madness
Was looking for that yesterday... think I will make it a sticky in the tech files...
Old Apr 5, 2010 | 02:01 PM
svt28640's Avatar
Default Cab lights
Ok guys i got my headliner down an everything marked out for my cab lights. Now the directions say drill 7/8 hole for center an 1/4 for anchor holes. But first do they need to be that big. And second should it have like inserts for the mounting screws cause mine doesent
Old Apr 5, 2010 | 10:47 PM
Just drill small and go bigger if needed. If I did it again I probably would only drill the wire holes and use self drilling metal screws to mount them but thats just me
Old Apr 6, 2010 | 01:28 AM
wesley's Avatar
That's what I done was use a 5/16bit and drilled 3 holes for each one.... The way I look at it the smaller the hole the Less likely it is to leak...
crashmarvin
Jun 15, 2015 07:10 PM
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
